32b TDI
Zollie
Re: 32b TDI
Beitrag von Zollie »
troublemaker hat geschrieben:Hi, you need these Sensors for the ECU. It`s for the fuel cut-off. Without these Signals runs the Engine very bad.
The Engine is electronically controlled.
In addition, you also need the electronic throttle.
I can make Pictures on Weekend, then you can see what i mean.
Have you managed to take some pictures?
would love to see them!
thanks, Zoltan
weichei65
Re: 32b TDI
Beitrag von weichei65 »
You have to look for an engine 1Z/AHU/ALE, they was build in the years - 1999 in nearly all cars, like Golf3/4, Seat, Skoda, Audi 80 Type89/B4, A4B5, A6 and so on. Your best buy can be an Audi 80 B4 with a 90hp-engine,because of parts for exaust and steering as Uwe told you. Don´t buy a newer engine like ALH or newer, they don´t fit plug´n´play. Kilometers about 300k are not the problem, you only have to check the injektors, if they are wrong, they can damage the engine.
Best wishes for your project, Thorsten
75 Barkas Pritsche
92 Volvo 245 D24
98 BMW Z3 1,9
94 Volvo 945 turbo
00 Audi A2 1,4
03 Audi A2 1,4 TDI
03 Octavia 4x4 TDI
Re: 32b TDI
Zollie hat geschrieben:
thanks, Zoltan
I will make them next Weekend. I Have too much other to do at the Moment... sry
Zollie
Re: 32b TDI
Me too! that's ok.
Bought myself an Audi 200 5T, it's taking up some time and gas now ;) But this summer I want to build the TDI in my 32b, still looking for a good audi80TDI...
thanks!
Zollie
Re: 32b TDI
allright!
The audi 200 is going for sale again, this thursday I am picking up a complete engine (170t km) and steering, computer and exhaust from an 1994 Audi 80 TDI!
Any small parts I should whatch out for? Parts I should not forget to take from the audi to build in to my 32b?
thanks
Re: 32b TDI
Zollie hat geschrieben: Parts I should not forget to take from the audi to build in to my 32b?
thanks
You must only read this Thread... :evil3:
My Pics are here :http://www.uwes-g40.de/ebay/32b-299/TDI/32bSyncTDI.zip
Zollie
Re: 32b TDI
Thanks a lot!
Isn't it easier to fix some engine mounts to put the engine on the subframe? Welding the 80 mounts in the car seems much more work...
Re: 32b TDI
I think the Subframe from the Audi should go in the Passat without Welding.
My Engine was implanted by the last Vehicle Owner.
Do anyone know more about the Subframe ? Pado ? Weichei65 ?
Zollie
Re: 32b TDI
In your car the engine mounts from the audi are welded into the Passat. I am going to look for a possibility to fit the engine on the subframe, have the engine in my shed, and a loose subframe, so I can play a little :D
Re: 32b TDI
Hi, the Motorbrackets are not weldet !
But you can take them from a JN Engine too. They fit also...
:occasion5:
