Sorry for continuing in English I'm from Holland. But please feel free to answer in German, I understand it very well.
I'm looking into building a TD engine in my 32b Variant. The car is now equipped with a 1.8 DS that will soon die
I want to do it quick, and easy
So now I found a Audi 80 TD with SB engine (LLK!) on a Dutch Ebay-ish website
My questions are;
* Is it possible to fit this engine on its own Typ89 mounts in my car, without welding or buying new mounts? I'm especially concerned about the front engine mount
* Is it a good idea to swap the subframe as well?
* Will the power steering be usable? Can I easily fit (plug 'n play) the steeringhouse and steering fluid reservoir?
* Will the Typ89 radiator fit my car?
* Will there be place for the intercooler/LLK?
Cabling and so will not be an issue, I already found out. I also plan to use my 2N gearbox, as the Audi gearbox has the same gear rates in 5th, and I've just built in a new heavy duty Sachs clutchset
Thank you in advance for your answers/links, it would help me very, very much!
Liebe 32b Grusse aus Holland,
Arne
