32b TDI project!
Zollie
32b TDI project!
Beitrag von Zollie »
Got the plan and lots of parts for more than 2 years now...
May 2010: Getting some Audi parts
Motor does not fit, I do not want to weld my chassis, so I need a Golf engine
got this 1981 monacoblue baby for more than a year now...
Found on internet (leboncoin.fr)
I got it shipped to my place, even with shipping costs it was cheaper than lots of 32b's on the web!
was completely taken apart, all blue!
oldskool paintings :)
and winter came, a new place to live... no playing with passats for a while
Got a 1Y motor to play with, and built it in the passat, but I did not like it.
out with this one
bought a 1Z engine from a golf, taking apart and fitting audi parts on it!
And electrics, lots of it
32b oil-pan
Turbo and stuff, the audi had 170t, it's a good turbo!
The 'package'
And some playing around with old water hoses, had to place the oil/water-thing, 32b hoses are hard to find for this...
There goes nothing!
Point of no return ;)
Exhaust fits nice
Some cutting here for the LLK
Fixing a steering-rod for the audi80 servo
unwrapping the electrics
cutting wires and taping back together
progress of making the pedal work with the electrical one
some cutting here for the wapu
I got a big watertank, so I am looking for a bracket and oil tank for 32b diesel with SRA. Anyone?
Also made wiring to generator and starter. Got the W-signal!
Some fixing for the rainy days in Holland...
Have to make the TD-pipe longer to fit onto the 80TDI pipe
That's it for now, more to come in the next weeks!
:occasion5:
Burt
Re: 32b TDI project!
Beitrag von Burt »
:respekt
Rock on!
Hey,
nice Projekt, good pictures and text.
I WANT MORE :notworthy:
Good luck and much fun with youre TDI Passat.
Greetings Manni
Zollie
Small update:
Fixed the pedal-to-gaspotti problem
To be installed tomorrow
Zollie
B4 filter fits!
LLK fits...
after some cutting
Gaspotti + creativity =
Credits for who can guess what part is used to attach the cable to the pedal 8-)
Zollie
Okay, a question for the guys who like to think a bit!
I am now using the 2N tranny, but it will result in more RPM's than I like...
What to do?
*nothing, get used to it...
*let the 2N tranny get 'tuned'
install B4 tranny
*it will fit
*axles will not fit (130mm)
* *custom axles ($$$)
* *B4 axles, B4 hub (Will it fit in 32b front suspension??) :-k
* * *4x108 in front?
* * * *Get 4x108 rear 200mm drums?
* * * *Let the B4 hubs get redrilled to 4x100? (if they can fit into 32b front suspension...)
What do you guys think about it?
(And how can I get the shift linkage to work?)
use the 2N.
Its a good transmission.
All other is to much work to fit it in a 32b.
Bye Manni
Zollie
but is it good for the engine??
2N -> 3250 rpm = 122 kmph
Golf TDI -> 3250 rpm = 163 kmph
I like to drive around 120~130 on the highway, thats 3250~3500 rpm. Does the TDI like this? I drive 35.000 a year, rides around 110km to work, 90 of them highway.
right, the tdi doesent like high rpms over long times.
You can search for 2M or MV transmission.
Its a Quantum transmission with long gears.
Greez Manni
Igor
Beitrag von Igor »
I think the 2N is the longest gear box you will (easily and cheaply) find in europe. Try to use a wheel & tyre combination with a larger diameter. You could try 195/60 15 or maye 195/65 15. Depending on the wheel offset, you will have trouble with contact to the wheel arch. It's worth a try, this is cheaper than anything and brings easily 7..10 % longer transmission. I had once tried 195/65 15 with offset of ET 20, what was a bit to heavy :)
Anyway, i like your project
