32b TDI project!
Zollie
Re: 32b TDI project!
Beitrag von Zollie »
No pictures yet, but got mself a nice spucknapf wheel! Radio installed, correct gearknob, it's nice now!
Also picked up the 2V gearbox, so I could start making the gearbox. Contacted some companies, but there is still one question...
Are the axles the same size? I want to swap the 2V gears onto the 3M final drive. But how can I figure out if the axles are same size? (with the gearbox closed :-k )
E.T.K.A. only gives different gear wheels. All bearings and meshrings have the same part number.
Is this enough information to assume that other than the worm wheel (Schneckenrad), the axle is the same? (I guess so..)
The other axle, that sits directly in the clutch plate, has the other gear wheels on it (some one-piece with the axle). I guess this axle can stay together. Does the 2V has the same connection to the clutch as the 3M? This would save some work!
Hope you guys know the right answer! :occasion5:
Zollie
Everything seems to fit... BUT
The axle that goes into the clutch/engine is longer on the 2V gearbox. The clutch plate fits perfetly. All I need to do is shorten the axle to the same size as the 4cil axle.
Good plan? I can't see any harm in it!
And just bought a Valeo 210mm clutch on ebay, 70e including shipping to Holland :occasion5:
Zollie
Hmmm, guess I'll just swap gears 3, 4 and 5, will be using them the most anyway ;)
Much easyer and cheaper solution, the splines for the clutch plate must also be machined some cm longer... hell of a job!
meanwhile, I got myself a steering wheel!
Mr_Sniper
Beitrag von Mr_Sniper »
Nice steering wheel.. sadly.. these don't fit plug &play into the 32...
Meine Fortbewegungsmittel:
- 1978er VKLE Jägervari LS
- 1979er VW Passat 32 GLS
- 1996er VW Passat 3B 1.8T
- 2013er Nicolai Helius AM
Zollie
Mr_Sniper hat geschrieben:Nice steering wheel.. sadly.. these don't fit plug &play into the 32...
Not in a 32? Why not? don't they have the same small hub? They come from early golf1, what is the difference with a 32?
Julian, das ist das berühmte "Spucknapf" aus dem Einser GTI und dem Scirocco I. Das habe ich doch in meinem roten Gaser auch...
Das passt freilich in den 32er...oder 33er...ist nur recht teuer hier bei uns, auch bei Ebäh ist es recht Teuer, selten ein Gutes noch unter einem 100erter...
schmidtla :bye:
Zollie
schmidtla hat geschrieben:
schmidtla :bye:
Spucknapf, 2V gearbox and a passengers side mirror: 100 euro :occasion5:
Mr_Sniper
Hä?Wollte mal ein Spucknapf kaufen weil mir das besser als das Raid das jetzt im Jäger ist gefallen würde.. aber angeblich wär die Verzahnung anders?
@ Zollie: If you can get another Spucknapflenkrad for such a lovely price.. I take it!
Zollie
Sorry, I got lucky. Normal price in Holland is 100~125 euro...
I bought stuff from this man before, now he had sold his SantanaGL5 and had to get rid of parts. I got lucky with the transmission and the spucknapf \:D/
mxzptlk
Beitrag von mxzptlk »
the spucknapf fits every VW from 08/73 up to 1988 (and later, when the adapter is removed). i have a black one in my '78 bug, i got it as a present (it was moldy, without horn ring). i got a horn ring on ebay for 55€ :D
'93 T4 Transporter, 2,4D
'78 Käfer, Manilagrün, 1200
